Electrical Usage For 1 Hours Use
(Stephen Kidwell) #1
To be a tad lazy as I am creating a master list of materials and costs I use for my little garage business, has anyone calculated how much it costs on average to run your Shapeoko 3 for say a hours use? I use the Makita router now if that helps. I just want to get as accurate as possible with how I charge customers for usage instead of possibly really under cutting myself.
(William Adams) #2
The Makita draw 6.5 amps when running at full speed — the machine ought to be around 2.5–3.5amps, depending on how hard the motors are running (they actually more current when holding position), so we can assume 10 amps w/ a bet of room to spare.
As the name implies, it’s 700 watts at full speed so to make things simple, we’ll assume 300 watts for the balance of the machine — 1 KWhr
So it ought to be a quarter or so per hour depending on your local rates — unless you’re running something with a heavy draw (such as an oven), it’s something you should factor in w/ your rent and other monthly overhead.
(Stephen Kidwell) #3
Your the man! Thank you so much!
(system) #4
