What happened to the Feeds and Speeds chart for the Nomad I checked for about 20 minutes tonight and cant find it anywhere on the Web
We’ve been updating our web site. To find this sort of thing now:
- http://docs.carbide3d.com/
- click on support: http://docs.carbide3d.com/support/
- click on the link to: http://docs.carbide3d.com/support/supportfiles/S3_feeds_250.jpg
which takes one to:
If you use metric there’s a text version at: https://www.shapeoko.com/wiki/index.php/Materials#Nomad_883 which you can copy-paste from
Hi Will
I’ve been confused for a while about this. Do you work for Carbid3D? If so what is your role?
Well, I’m a member of “Team Shapeoko” https://www.shapeoko.com/team.php and received a Shapeoko 2 in exchange for doing the instructions: http://shapeoko.github.io/Docs/ and was a long-time volunteer on the wiki and did some freelance work and also a moderator/admin of the Shapeoko forums, as well as here.
Got hired to do part-time, off-site tech support at the end of last year, so do work for Carbide 3D in an official capacity — not really sure what my role is, just try to pitch in and help out where I can.
I see, that’s a very detailed answer, now I know what you do for carbide 3d perfectly Thanks for taking the time to explain. You certainly pitch in on this forum a lot. Especialy on the threads I follow at least.
Thanks for asking. I was curious too.
