Fixture Clamps, 10ipm, 0.2mm doc, 10krpm, 1.5mm load 14hrs
Here’s my fusion file: https://a360.co/2Jxklbc
1/8’’ ZRN endmill (I also have a 3/16’’ zrn and 1/4’’ zrn) rough it with 1/4? I was trying to stick with smaller endmill to keep it quiet.
10k rpm, 10ipm, 0.2mm doc, 1.26mm optimal load, 1in plunge, 5in ramp, both ways.
2 deg ramp angle, 12deg taper angle, 0.5mm clearance height.
am I doing something wrong? It seems like these are the “avg” speeds and feeds everyone is doing…I’m pretty sure this is not normal for everyone right?
What things can I speed up without stalling the machine?
I run my 1/8" carbide mill at .08" depth of cut and 60 ipm.
Are you cutting aluminum?
sorry ya, 6061 aluminum
