I am looking for the gCode command to move the router to the top of the Z axis.
This will be part of a script to use the probe to zero the Z axis. I am not using the Carbide 3D probe. Once set, I want to move the router to the top of the Z axis so I can reattach the dust boot and get back to work.
If it matters, I am setting the Z axis zero to be the top surface of the work piece.
If I could home the Z axis that would be good. But as near as I can tell the only homing command available works on all three axis and the movement in X and Y direction would be counterproductive.
But keep in mind this will change your coordinate system, I don’t know how to tell what coordinate system it was in before you do this so you can put it back.
