when i set up my surface bit to clean my waste board.it only moves a few mm
I made a void in the waste board for my nomad by making the work area 8x8 in carbide create and then I made an 6 inch square that I made a pocketing operation on in toolpaths tab. Should be about the same workflow but change for your machine and desired size.
Please see
and
Thanks for the help
This should help with my problem
I was using the texture set up
Should have used the contour
