The result of not having my inlay weighed down properly during the glue up
Removing the excess stock to see what damage I’ve done
And I can salvage 4…
IF you can find a bag large enough and have a good strong shop vac or vacuum pump pulling a negative pressure is about 15 lbs per sq. in. atmospheric pressure. On large areas like that the bag should work well for what you need.
Need one of those “space saver vacuum bags” for storing sweaters in!
