How to import a DXF from Creo
(Dan Oelke) #1
I have a Shapeoko 3 that I just cut my first aluminum parts on this past week. That went really well.
Now my problem is that the robotics team I coach is used to using PTC Creo as their 3D CAD package. The one student figured out how to export a DXF from Creo but when I go to suck it into Carbide Create I get a message that there are 0 elements and nothing shows up.
I played with it and used a number of different options such as:
Export splines as polylines
Use DXF version 2013, 2010, or 2000
Export Sheet as “Model space” or as "paper space"
a few others I don’t remember
Nothing seemed to work.
Now I installed Inkscape and used it to import the DXF and then save as an SVG. That helped a little in that I can see the curved lines now - i.e. the holes and the ends of a slot. But it doesn’t show any of the straight lines that make the outline of the object.
So - has anyone been sucessful in exporting a DXF from Creo and into Carbide Create? If so - what’s the magic formula i’m missing??
(William Adams) #2
Just fixed a file (yours?) on the support queue by:
  • opening in Inkscape
  • fixing all the non-closed paths
  • re-saving as SVG
  • importing (but the open-ended paths were left out)
The community has notes on this sort of thing at: https://www.shapeoko.com/wiki/index.php/Carbide_Create#Import
it may help to use the OVERKILL command to eliminate any overlapping or intersecting paths before exporting from AUTOCAD
AutoCAD 2000 DXF format (model geometry only, base model scaling) export from the desired face (not isometric view)
2004 Lines
it would be nice to have a similar set of recommendations for Creo, but I’ve put your file in to have a developer look at it.
