Hello fellas. I’ve been having to run most of my work on Artcam, and I’ve tried both the nomad post-processor as well as the Mach3-mm, and both give errors when opening them up in Carbide Motion. They run just fine on universal gcode sender, but I really need to get it working on Motion (for end-users its way more friendly).
The error always seems to be: Error in line 4: unsupported G code.
I suspect that the problem is that all those commands are on one line (they are supported) — please edit your post-processor to put them on separate lines — if that works or no, let us know.
Well, I just followed your instructions on separating each instruction to a different line. Now I get an error of unsupported gcode in line 6, which corresponds to G80.
This is how the beginning of the code looks like when exported from Artcam
Yes, G80 is motion mode cancel — it’s included out of an abundance of caution to ensure the program starts running in a known state — since the modes in question aren’t supported by Grbl, while it’d be harmless to send it (so it’s supported by being ignored) there’s no need to send it since the state which it cancels can’t occur.
Quick question, since I haven’t been able to find it: Is there a way to change the behavior of the Stop button on Carbide Motion? When I wanna abort a run, the Z plate starts moving downwards and always hits the material I have clamped. I have to cut the power to the machine or it keeps going down.
