Issues with linoleum
(F B) #1
I’m trying to figure out why cutting linoleum works great with my 1/8 endmill and gives nice edges, but with my 1/32 bit it is fuzzy.
With 1/8 (carbide3d #102) @ 60IPM 12plunge .06/ deep I had great results.
When did my detail pass with 1/32 2 flute (this one) 30IPM 9 plunge .05 deep, the edges are fuzzy. I tried over riding the feed up 20% and down 20% at various speeds on the makita, with no improvement. Is this the wrong cutter for this?
(William Adams) #2
Most likely it’s a matter of balancing feed and speed.
For the 1/8" endmill, calculate out your SFM and chipload, then compare with what you’re achieving for the smaller endmill.
One technique for testing feeds and speeds here: https://www.precisebits.com/tutorials/calibrating_feeds_n_speeds.htm
(F B) #3
I haven’t done this before, so bear with me
I think
The 1/8 SFM is 18000 (RPM) X .125 (diameter) X Pi / 12 = 589
The 1/8 Chipload is 60 (feed rate in IPM) / 18000 (RPM) X 2 (flutes) = .0017
The 1/32 at current settings is
SFM is 18000 (RPM) X .03125 (diameter) X Pi / 12 = 147
Chipload is 30 (feed rate in IPM) / 18000 (RPM) X 2 (flutes) = .0008
SO
If I want to increase the SFM, the max I can get to on the 1/32 endmill at 30K RPM would be 245 (only half of the 1/8)
And for the chipload i could double the feedrate to 60IPM to match. Would that be advisable to try? Is there something else i can do to increase the SFM?
(William Adams) #4
For the hobbyist machines, it can’t be purely about numbers — you have to go by the feel of the machine as it’s cutting.
More information (some of it contradictory) at: https://wiki.shapeoko.com/index.php/Materials#Linoleum and the balance of that page.
(Richard Cournoyer) #5
Ummm, can I just leave this here: (PS there is one more video to this series)
(F B) #6
Timely!
However, based on this, my settings outside of DOC are pretty close for the 1/32 mill.
He recommends
1/32" 2FL Endmill @:
10k RPM
25 Inches per Minute
0.02" Stepdown
My settings were (at one point)
10k RPM
27 Inches per Minute
0.05" Stepdown
In this case, will .03 DOC and 2 IPM make the difference? He did mention that not cutting as deep would help with chip clearing, but I’m thinking the type of linoleum we have might be more of a factor. I’ll have to do some more experimentation.
(Csaba Horváth) #7
I have not worked with linoleum yet but what I have noticed with this small end mills that a slight increase in DOC can cause a lot of troubles. So I would start to reduce that first.
(F B) #8
I’m definately going to try less DOC. There are some people on the inventables forums saying the gray lino that i purchased is not great for carving and can have this issue, but the tan lino doesn’t.
(Jesse Glessner) #9
Some of your problem might be the age of the linoleum. If it has any age at all, say a year old, it could have hardened.
You might also try a ball nose bit if that will work for you.
