Steve,
Thank you for being so active on the forum!
Im really impressed with the work being posted,…
The Carbide3D community is an amazing group of people, and potential.
Im humbled and honored to be able to participate.
Here is a screen capture of the tool path I used for that part:
<img—These were all cut dry- and I occasionally vacuumed the chips out of the channels when waterline cutting the perimeters of these metal parts.
Heres some other small parts and settings:
As more people start experimenting with metals, a couple pointers;
Securely Hold your work, the wax is great, tape wont do it here.
Check your spindle belt tension, remove any slack from the belt, the four 2.5mm heads to adjust the belt tension can be accessed through the bottom of the Z carriage.
Happy Saturday, and Happy Fathers Day!
-Apollo
