I’ve put limit switches on my s03 with some homemade brackets. I’ll probably make real mounts out of aluminum sometime (anyone have a 3d model for those?)
Anyway, my cobbled together brackets reduce the table area some. I think I’ve set the area correctly when I try to go to edges the machine stops where it’s supposed to. It homes correctly so long as the gantry is 6-8" away from home in the back corner. If I stop the machine closer than that, then cycle power and home, it keeps going even when the limits are hit.
Any idea what’s going on?
