dear carbide team
I find it odd that carbide create imports a dxf in inches, even if units are set to mm in settings. this is really not logical behaviour and will also confuse a lot of users. I can easily change my units in rhino from mm to inches and then back again after exporting, but that’s not really a good workflow, is it. also, a fix to import to mm should be really easy to implement… please?
thank you!
