My first piece!
(Reid Forrest) #1
After a couple of weeks of building, tinkering, and learning Fusion 360 I finally have my first success! I cut this from plywood, stained, and mounted it. And cracked open a bottle to celebrate. Had to test it of course!
(Richard Herring ) #2
Fantastic job my friend! :ok_hand:
(travis) #3
Nice work Reidfo :+1:
(mark robinson) #4
Great Job!..
(Neil Ferreri) #5
Can you share how you mounted it to the wall?
(Reid Forrest) #6
I used the mounting holes for the bottle opener. I just drilled straight through and used drywall anchors in the wall.
(Steven Zara) #7
Looks great! Can’t beat the feeling of a successful project! Question; Did you chisel the inside corner on the left “L”? I don’t see the rounded corner that a bit usually leaves.
(Reid Forrest) #8
The whole thing was cut with a 1/8” flat end mill and then sanded. There is a very slight round to the corner you mentioned.
