Ran across this plugin for Fusion360 today, seems to work well, has a lot of capability. I think I looked at a much older version of this that wasn’t so sophisticated.
Have you used/tried it?
Anybody?
I’ve run it, made a model, but not generated gcode yet.
I tried that quite a while ago. If I remember correctly, I had issues getting from the mesh to anything I could run CAM on.
" Convert the Mesh to a BREP
- Enter the Model environment
- Select the Create->Create a Base Feature item from the toolbar
- Right-click/Ctrl-click on the mesh and in the context menu, select Mesh to BRep.
- In the dialog displayed, the mesh should already be selected. Click OK."
I’ve had this work - this didn’t have any directions before, now it does, and they seem to work.
