Nomad build plate jam
(Amanda ) #1
I hope someone can help me. My 883 pro has been working fine until I started up a new project and during the initial homing process the build plate which was all the way forward jammed , making a horrible noise. I turned the unit off and tried to move the plate toward the center manually but it is stuck, unmovable. When I turn the Nomad back on it shows a limit switch error. How can I get the build plate moving again.
Thanks for your help!
Amanda
(Ryan Carstens) #2
I had that problem because I did something very dumb…
(Amanda ) #3
Ok, I’m an idiot. I used the wrong bolts to screw down the wasteboard and it basically screwed the build plate into place. I hope I didn’t screw up my Nomad.
(Ryan Carstens) #4
Mine was fine after.
