Nomad Specifications
(Stephen Needle) #1
Hi if anyone can help me with some data please?
I’m looking for the following info regarding the Nomad 883 Pro machine;
Motor steps per revolution?
Distance per revolution of the thread bar in each axis (I assume they are all the same)?
Maximum feed rates for each axis?
Any help would be appreciated if this data is available.
(William Adams) #2
My Nomad has the motors set to:
$100=200.000 (x, step/mm)
$101=200.000 (y, step/mm)
$102=200.000 (z, step/mm)
Lead screw pitch (for Pro variant): 8mm per Mach3 for Namad 883]
Motors are NEMA 17, 2A per Mach3 for Namad 883 — you should be able to use the above numbers to derive the micro-stepping being used per https://www.shapeoko.com/wiki/index.php/Grbl_Configuration
Max. speed is listed at: http://carbide3d.com/nomad/specs/
Max Speed (X, Y): 100in/min
Max Speed (Z): 50in/min
(and in Grbl set to 2600mm and 1270mm respectively)
