Paint a sign with several colors
(Idan) #1
Hi folks, I cut this sign out of plywood and it came out quite nice:
So I wanted to paint it, and aimed at getting this:
The two shades of brown aren’t that important so just one style of brown is fine.
So I started with spraying the whole thing brown and then tried doing the white regions with acrylic. It got really tricky doing the letters and the mountain. Even with the smallest brush I could find, it came out pretty bad:
I think the green region is going to be even more difficult because of the trees. So it seems like this is not the way.
What would be a better way to get a decent result?
(Daniel Loughmiller) #2
Paint it brown, let it dry, cover the whole thing in painters tape (get a wide roll to avoid going batty applying it). CNC through the tape, then make sure the tape is pressed down around the edges of the cut. Paint the recesses, peel off the tape, and touch up.
My thoughts anyways.
(Pete) #3
I have done it this way in the past with some decent luck.
Paint all recessed areas first, dont need to be precise with over painting.
Run the piece through a wide belt sander, or use a orbital sander to sand any paint from the top.
Take a foam roller and roll the brown paint over the top, using little to now pressure and light coats. This will ensure no paint runs down into the lettering.
Your parts looks great BTW!
(Adam X) #4
Down cut bits will make the masked surface cut cleaner too…
