Pink Outline on Carbide Create
(Caleb Nitz) #1
I am attempting to set up a build using Carbide Create, and I am importing a DXF. When imported (opened), part of my design is outlined in pink as opposed to black (though will transition to an orange outline if clicked or selected, like the rest). I am unable to set a toolpath to the pink outline and I’m not sure why.
Any ideas?
(Caleb Nitz) #2
I did just download the newest version of Carbide Create. If anyone else wants to try out the file, it is attached. It’s just the Star Wars logo.
SWL4.dxf (269.3 KB)
(Caleb Nitz) #3
Slight development . . . in case anyone else comes across this thread with the same problem (not yet sure of a solution, but . . . ) I am able to create a toolpath that has an offset direction of “no offset”, but I am not able to choose a different offset.
(Caleb Nitz) #4
SOLUTION: Two of the mating lines did not terminate at the adjacent end points, but instead, one of the endpoints terminated along the other line, thereby creating a loose end. Once I trimmed that properly, everything worked.
(Brendan Ford) #5
Did you ever get to the bottom of the pink issue?
(William Adams) #6
As noted on the wiki, Carbide Create has limited support for open paths: http://www.shapeoko.com/wiki/index.php/Carbide_Create#Limitations — best to close them before processing.
If need be, expand the path in your drawing program to the desired cut width (so long as that is at least 10% greater than the endmill diameter)
The manual discusses this as well: http://carbide3d.com/carbidecreate/userguide/#polylines
Pro-Tip: The color of the line is a visual indication of the status of the object you are creating. When the line is purple, the object is ‘open’ and cannot have a toolpath applied to it.
It would be nice to have support for open paths, and the ability to cut open closed paths as well as a “follow path” toolpath option.
(Caleb Nitz) #7
There are still scenarios where pink lines show up and I can’t figure out why. What I usually do in these scenarios is trace the troublesome line with a spline and then convert the spline to a multiline. The new line is usually accepted by Carbide Create, though this is more of a workaround than a solution.
(William Adams) #8
Please send any such problem files to support@carbide3d.com, along w/ the source if possible — hopefully we can build up a suite of test files and fix this in the code.
(Daniel Montgomery) #9
I wrestled with this for hours and searched here for a solution. I found the solution, although it isn’t efficient. For anything on your design drawn in pink, as you know will not be carvable as a pocket or texture. To change it to black and have all tool path features available, go to the design mode of carbide create, make sure all shapes involved are not nested/grouped. Select them one at a time. When you do you will notice a “join” option appear in the edit box to the left. Click that option and the selected shape will turn black and become carvable. The real pain is that you have to do this with every single individual shape and can’t simply select the group, as far as I know. But it will allow you to finish your project the way you envisioned it. Happy carving!
