I am about to cut a paddle out of Oak, now there is no chart about Oak, but I figured I would give it a shot and mill it with the .25" cutter and use the Mahogany Speeds and Feeds.
-I have the Makita Router.
Just have a couple Questions:
-I notice that the “speeds” is significantly faster than say my nomad. To Cut Mahogany its about 9200 RPM, the for the shapeoko its around 19,000.
-However does this speed even matter? You are setting the router to 3.5, so is inputting a speed not necessary on the shapeoko?
-I also notice my plunge is deeper on the Shapeoko, is this due to the fact I’m using a bigger cutting tool?
-Also on the shapeoko chart what is: m/m, CPT and MRR?
Run a .25 inch end mill in oak at 30-40ipm feed, 25ipm plunge, .1" per pass, rpm as fast as the makita can go. It’ll be fine Wood is pretty forgiving of cutting feeds and speeds as long as you’re not bogging down the cutter by taking too deep a pass too quickly
