Hi guys - I had an issue on the weekend where I wanted to cut a rectangle shape that was 100mm wide. It was to fit into a slot that was 100mm wide - simple male/female fit.
I was using the .125" Endmill and chose an outside cut - it is tool 201 in CC and that was the tool I used. My assumption was that CC would account for the tool size and cut the perimeter of the object such that it would be 100mm wide. That wasn’t the case - it ended up approximately 103.8mm wide.
What’s going on here - am I missing something? Is there some part of the tool width I need to manually account for? Is there potentially another issue I’m not aware of - calibration? Thanks.
CC does account for the tool diameter, and the machine accuracy is around +/- 0.1mm (at the worst), I’d say this was probably operator error. You should always post your CC c2d file too so that we can look at your setting.
Operator error? I’m not familiar with that term…
#201 is the 0.25" end mill and #102 is the 0.125 end mill. Your machine thought it was cutting on the line with an end mill twice as wide as you were using.
You know what - you might be on to it. In my mind I know #201 is quarter inch and #102 is eighth inch but I may have got them mixed up when selecting them in CC.
This clearly isn’t operator error - i’m blaming your “freedom units”…y’all heard of the metric system yeah?
Just checked my file and you were right Maxamillion, I was using a 0.25" bit while selecting a .125" bit in CC and when using the 0.125" I was selecting 0.063" in CC. So simple, but big difference, thanks.
You are not the first creator to mix up the bit selection, either in the design or at the machine, nor will you be the last. I have generated G-code with two different bits into one file… the results are not what you were hoping for when the machine continues on to the v-bit toolpath with the 1/4" endmill that was used to hog out the initial material.
