SO3: Compiling latest Grbl [SOLVED]
(Tim Foreman) #1
I want to install the latest version of Grbl on my S3 controller. I downloaded the source from GitHub, modified the config.h file and compiled the hex with the Arduino compiler.
I used my USBTiny programmer to flash it to the controller and it appeared to load fine.
But when I connect with bCNC it doesn’t seem to be responding correctly. It makes the connection, but Grbl doesn’t appear to be responding.
I’ll be doing some more troubleshooting this evening but I was wondering if there was a list of any special S3 specific settings in config.h that I might have missed.
Thanks!
(Tim Foreman) #2
Digging in the Grbl source I see one thing that I missed. In config.h I didn’t change
#define DEFAULTS_GENERIC
to
#define DEFAULTS_SHAPEOKO_3
But as far as I can tell that shouldn’t affect the communication. I’ll re-compile and re-upload this evening and then do some testing.
(Tim Foreman) #3
Okay, well, I solved my own problem.
I used my USBTiny to flash a bootloader onto the controller then I used the Arduino IDE to compile and upload the code through the USB port.
That appears to have worked quite well.
Of course I didn’t write down all my Grbl settings before I started so now I have to re-calibrate my steps/mm settings. Oh well, at least I have a process for that.
(Kevin Carrico) #4
if you don’t mind… and since i have a sparkfun SO3… do you know what the default grbl settings for the SO3 are?
EDIT: never mind, i shoulda searched first — my apologies.
http://docs.carbide3d.com/article/38-shapeoko-3-default-grbl-settings
(Charles Peterson) #5
Anyone know where I can get a copy of that settings file? This link is broken.
maybe it is this one?
