Spindle Mount Screws
(Miles Baughman) #1
I accidentally used 2 M5x10mm screws on the spindel mount instead of the M5x16mm. They are locktighted, but should I change them out or is it ok?
(William Adams) #2
That’s not much thread engagement — it would be better to use the correct length. Worst case though if things let go is you’d need to use the longer bolts or drill and tap deeper holes.
(Vince) #3
Heat will release hardened loctite btw.
(Miles Baughman) #4
Got it thx. I think it will be fine.
(Luc) #5
For less than a buck of material, I would change them ASAP and put the right length bolts. The cost of a failure could be significant not to mention disruptive.
(Miles Baughman) #6
I changed them thanks for the help all!
(system) closed #7
