Stepoko Board and Carbide Motion
(Anthony Bennett) #1
I have the Shapeoko Sparkfun edition I purchased in December 2015. After a couple months of using it I was forced to put in storage until here recently. Since getting it setup up again, I am able to use Universal G-Code Sender and the Inventables Easel App but every time I try to get into the Carbide Motion app I get a Grbl Error:Cutter not found. I’m not sure where to start to get this running again. Any suggestions?
(William Adams) #2
Do you need to re-enter the activation code?
Contact support@carbide3d.com w/ your purchasing information if you need one.
(Anthony Bennett) #3
I can definitely try again but I’m pretty sure that was all done correctly. I will let you know if it works.
(William Adams) #4
If that’s not the case, then I’m guessing you’ve updated to Grbl 1.1, (or haven’t updated and are using CM4?)
Please see: GRBL 1.1 and Carbide Motion 4
(Anthony Bennett) #5
As far as I know nothing had been updated since I purchased it in 2015. Would that cause compatibility issues if it wasn’t running Grbl 1.1? I have an email out to Carbide support. Just waiting on a response now.
(Anthony Bennett) #6
Hey William, that worked! Thank you for your help!!
