Syntax Error from Vectric on Nomad
Purchased and started using Vectric VCarve Desktop. I did install the post processor for the Nomad. Went to load and test cut a file this morning and got the attached error. I’ve also uploaded the gcode. Any help would be appreciated!!!
Brooks Sample.nc (52.9 KB)
If I remember correctly this is caused by a space appearing before the % comment symbol.
You should be able to avoid it by using the correct post-processor or editing the post-processor so that it doesn’t insert that extraneous space.
