Touch probe Set up
Just received my Shapeoko Touch Probe. I attached the connector to the “reserved” spot on the board. I can not find anywhere that tells me where to connect the clip! I know one end goes on the cutter but where/what does the other end attach? Please help.
Thanks, Joe
Almost anywhere on the frame should do it. It’s the ground.
Thanks Luke I figured as much but wanted to double check.
I’m suggesting the screw for the controller PCB securing it to the heatsink nearest the USB port.
You need to run the wires through the cover before attaching them.
Thank you
