Having trouble generating the proper toolpath for a shallow depth of cut when using a V-bit to do a contour.
In Carbide Create V-bit depth, on a contour toolpath, uses the max cut diameter of the tool to generate the toolpath regardless of the max depth of cut I set (even though the cut diameter is now less). Is there a better way to set up V-bits for contours when not using the max cutting diameter?
The max diameter should be a limit, not always used β you can see this by making a large square and then assigning a V carve path to it β the result is an X shape / four sided star.
The other control is how wide the geometry is β you can offset geometry and select it in addition to control where V carves will be made.
