WillAdams
(William Adams (Carbide 3D))
1
Looked a bit, but not really finding much.
Asking 'cause I’d like to use the expected units, and I’m tired of doing the calculations in Imperial and then converting.
This page: Machining Feeds and Speeds Calculator list one:
SFM (surface feet per minute) is instead m/min (meters per minute)
I’d like to know the metric for chip load per tooth in particular, but any information on conventions would be welcome
mikep
(mikep)
2
Just use meters instead of imperial for everything.
“Chip load is the depth of cut for each tooth on a milling cutter”
so, meters instead of fractions of an inch (and a much smaller number!) .
WillAdams
4
Yes, that does help. Doesn’t cover everything, but does have some information / formulas / calculations I hadn’t seen before.
