Tried to do a simple 4 hole cut 1st hole correct dia.and depth, 2nd hole correct dai. but depth was shallow, 3rd hole correct dia. but the depth keeps getting shallower, 4 hole same issue, depth keeps getting shallower.
You are skipping steps in your Z axis.
Can be loose belts, dust shoe causing skip or loose set screw.
You should be able to see it or hear it skip during the operation. Run it again and pay close attention.
Thanks Rich, I checked the set screws and found both to be tight, but I did find the pulley at the bottom of the Z plate to be lose, re-tighten and applied Lock Tite and it seems to be working. I think I will look into replacing the screw with a longer one and a lock nut. Appreciate the help
I checked the set screws and found both to be tight, but I did find the pulley at the bottom of the Z plate to be lose, re-tighten and applied Lock Tite and it seems to be working. I think I will look into replacing the screw with a longer one and a lock nut. Appreciate the help and insight
