Anyone know if I can swap out the plug to a different connector as long as it is using the C13? I was looking at using this power cord. It came with a standard plug, but I did get the 220V chiller.
I think you have a 220v/240v only power for the chiller. European 220 v is standard and is not two 120vAC sine waves like in north America. European 220 is a 220v sine wave where North American is two 120vac sine waves. A lot of “Single Phase” are auto 120/220 switching or they have a manual switch on the power inlet. Since it ways 50/60HZ I think it would run on 220 European plugs but not on a 20AMP 120v outlet. It would need to be a 220v.
You should check with the OEM to see if it can run on North American 220v or only European/Asian 220vac power. Maybe one of the engineer types can chime in.
This was the chiller I got when I purchased my 80mm spindle from Carbide3D. So I assumed it can run on a 220 outlet. Maybe I need carbide to swap it out for me?
@Luke should be able to speak to that from personal experience, but my understanding is that what you describe is what is supposed to happen — I see you have a ticket in w/ support, so we’ll have someone competent verify this presently (and then I’ll try to make a note of it and remember it for the future).
Thanks @Luke and @WillAdams . I got the new plugs and everything seems good. I haven’t set it up as a new machine in carbide motion yet, is that even necessary if going from the 65mm spindle to the 80mm spindle?
If you are going from a compact router to a spindle, you would need to. However, if from the 65mm air-cooled spindle, there should be no need to re-setup the machine.
