Need to get my hands on a .25" ER-11 Collet and Nut before my Nomad arrives but everywhere is out of stock even on the carbide site so my question is can you buy an after market one that will fit the nomad? Is the ER-11 nut a standard size or does the thread vary? UK based so would prefer a UK supplier
and was quite pleased w/ them. Planning on getting a full set of metric collets and the castle nuts to differentiate them from Imperial when I have a job which warrants it.
Some collets are sold with a 0.5mm clamping range, so you can get a 6.5mm metric collet and use 1/4" endmills while remaining within spec. Make sure that the collet is specified for that clamping range though, many are only suitable for the nominal diameter.
I’ve used them before, they’re a decent supplier. Their ER collet nuts are not balanced for high speed spindles though so you want to find another supplier for the nut. I have not been able to find a decent supplier in the UK for balanced ER20 collet nuts yet, I’ve been taking AliExpress pot luck, buying bags of 3 “precision balanced” and throwing away the two worst ones.
And if “the powers that be” are going to remove useful information from the wiki, maybe we need to copy it somewhere outside their control. Maybe @Julien’s book?
I noticed the page about the Shapeoko e-stop had been removed too.
