$30 setting for CM?
Hi Ed…my macros do set $32 correctly (as you stated). The parm in question is $30. I had to make a change in my “Use Laser” macro to add $30=1000 (1000 being what Lightburn knows as my “S-Power-Max”) to it. I then altered my Use CNC macro to reset $30=1. The handling of $32 did not change and is what you mentioned.
My question is how my $30 got set to 24000! At first, I thought this was some random number, but it turns out to be the proper $30 setting for the HDM - so it’s my guess CM set it somehow. Anyway, I don’t have the problem anymore!
  • Gary
