3D file for Vectric Vcarve
What vectric calls “3D” is 2.5D images. VCarve allows you to use the clip art and modify and carve them, but Aspire has the tools to create your own clipart, such as using a vector to create a raised plane, rounded curve, or pyramid. These are the tools I was thinking about when I described how to convert the vector into a “3D” model. What Vcarve would do for you is allow you to use those vectors and a v-bit toolpath to carve them into the wood, similar to the first picture I included, the barber nameplate. I’m not sure about a vector to clip art service.
