I just purchased the SMW Fixture Tooling Plate for my Nomad, and to install it accurately I obviously need to use an indicator to make sure its square to the machine, so I’ve designed this indicator bracket.
It attaches to the left side of the spindle using the 2 M4 threaded holes, and uses a M5 threaded insert (from McMaster-Carr) to hold the arm.
The link to the fusion360 file can be found here, so if you want to modify it or mirror it, feel free (its meant to be 3D printed)
Heres a screenshot of it in Fusion. The cylinder/bore/barrel is for the insert, so that the arm threads in pointed downwards to maximize the length of the indicator arm, as its pretty short.
Parts List:
Digital Indicator - https://www.amazon.com/dp/B07R5MKSFZ?psc=1&ref=ppx_yo2ov_dt_b_product_details
Indicator Arm with M5 Threads - https://www.amazon.com/dp/B07JFTBSC9?psc=1&ref=ppx_yo2ov_dt_b_product_details
M5 Threaded Insert - McMaster-Carr
