3d rough cut not working
I am trying to the get my 3d rough in to work on a project I had already done it once but now it won’t load the tool paths at all same with the 3d finish the features.
do you mean it does not load in Carbide Motion (what size is the file ?) or in Carbide Create ?
it will not load the tool paths in carbite create. I was able to get it to work in fusion 360 but was just crazy I had use that solfware vs the carbine create.
Please let us know step-by-step what difficulty you are having and send the files, along with instructions for causing the problem in to support@carbide3d.com and we’ll do our best to work through it with you.
There was a bug (or two) in the 3D roughing that was fixed in the current beta at:
https://carbide3d.com/carbidecreate/beta/
I’m not sure what was causing your problem but it could have been related to those bugs so it’s worth a look.
thank you the beta actually worked vs the regular solfware with the pro trial.
Thanks for the feedback. We’re hoping to move it to “released” in the near future if we don’t get any reports that we broke something else.
