I am in the middle of testing a 3rd party controller. I had it doing $H a few times but after an hour or so it got into a mode where it does the Z home and the X home as expected but not the Y. I doesn’t even move in Y during home. I can cut things just fine. This only happens during homing.
Trying to come-up with a theory to fix this. Any ideas?
Yes Will that is on my list but it doesn’t explain why it might have changed when I didn’t set any parameters. I glanced at a $$ dump and didn’t see anything obvious but I will step through it tomorrow. Also checking the limit switch wiring since I have been having trouble with that.
I’ve had some trouble with these myself. They seem a lot more fragile than I would think they should be. As long as you don’t fully depress them, they seem to hold up ok. I’ve broken a couple, and both times because I was moving things around by hand.
I installed the Simulated Roller Version of this microswitch. Thought it would give me a little protection against accidental destroying the switch. It does cost a very small amount of X, Y and Z movement though.
