What machine are you using? standard 118 and 135 degree tip 4mm carbide stub drills work great peck drilling 6061 aluminum with full retracts at 10k rpm 30 ipm .04" peck depth on my HDM with mql air blast. You don’t need expensive drills just run the shortest drill needed to get through the material.
