reedlabs
(Reed Smith)
July 20, 2023, 2:20pm
1
Is there a maintenance guide somewhere? At least something for the HDM? I’ve seen posts talking about the need to oil, etc but can’t find any information or diagrams on that at all. Old posts here had C3D employees saying they were creating one but I can’t find it if it exists.
Reed
WillAdams
(William Adams (Carbide 3D))
July 20, 2023, 3:02pm
2
reedlabs
(Reed Smith)
July 20, 2023, 3:57pm
3
Thank you, Will. I had not seen that and couldn’t find it when searching either.
Now, I’m hoping someone can post a pic or diagram of this part as I have no idea where these service areas are located:
HG-15 Linear Bearing Block Maintenance
Open oil port by removing the M4 grub screw.
Using a pipette, put 3-4 drops of oil into the port.
Replace grub screw.
After all bearing blocks are lubricated, jog the axis back and forth in Carbide Motion to distribute the oil.
CullenS
(Cullen Simpson)
July 20, 2023, 4:09pm
4
Not the same Z you have but check this link
It’s only about a 20 minute job when you do it a few times. BTW, a small drop of oil in the hex of the grub screw will help the screw to stick to the hex wrench when reinstalling the screw.
system
(system)
Closed
August 19, 2023, 2:20pm
5
