65mm spindle drifting down
I have a 5.1 pro, about 2 months, and today the spindle drifted down about a third of the way when I turned the power off? First time this ever happened. I restarted the machine later for a cut and everything worked well, when I finished for the day and turned the power off it did the same thing??
My Pro XXL does that randomly. May not happen for a months and then it’s every time for a while.
C3D has a fix. It is a hydraulic cylinder that keeps the spindle up.
Some people just put a piece of foam under the spindle when they shut down.
Thanks Guy for the information and video link
David
My 65mm spindle has done that from day 1 on my pro 5. I’ve just decided it isn’t that much of an issue and let it do its thing. I thought about the hydraulic cylinder by decided…“Nah”.
Is the 65mm spindle significantly heavier than a compact trim router? I have an SO3 XXL with the HDZ upgrade and don’t think I’ve ever had that issue, but assume the newer components are heavier?
I put blocks of wood under the Sweepy frame in case it drops.
When I got my 65 mm spindle I was shocked at how heave it was. I only have the Z Plus on my machine and it’s hit or miss whether it drops at shutoff.
I have a 65mm spindle and HDZ on my 4XL and have never had the spindle drop.
If memory serves me right it’s because the thread pitch of the ball screw is different on the 5.
