How to draw:
Start by guessing at the size and setting the origin to center and grid to 0.25in:
Make a copy of the pixel image and place it centered on the background as a guideline:
Draw circles of a suitable size:
Draw a rectangle of a suitable size:
Draw a small circle:
Draw a large circle:
Duplicate the small circle:
Drag it back into alignment with the original and then select the large circle:
Rotate 180 degrees:
Duplicate parts, drag into alignment, and then rotate using the largest circle:
repeat as needed:
At this point you have a choice:
We will show the former here and leave the latter as an exercise for the reader.
Starting with the figure:
we duplicate the central small circle, select everything but it and the largest circle and do Boolean union:
resulting in:
reposition the small circle:
Select the unioned shape and the circle and switch to the model tab and create a model shape with suitable parameters:
Using some technique for two-sided cutting one should then be able to cut this out in two operations.
Ho , Willy thanks a lot for this 8 pointed star , best my friend . looks very good .
Very nice example
