I try to load a 90° bit into the tool library and when I type in 90 for the degrees it shows up red and won’t load any tips?
Depending on what software you’re using, it may want the taper angle rather than the tip angle which is half (45 degrees).
Watch the one on V carving, Should answer all your questions
Im using carbide create
Got it thanks guys I have to use half the degree of the bit so a 90 I have to type in 45
