I’m entering a few new bits i picked up and having trouble with entering the numbers of a 90deg vee mill (https://www.whitesiderouterbits.com/products/1502)…
I enter 90 into the angle and it turns red and prevents me from saving it.
Does anyone know what I’m doing wrong?
WillAdams
(William Adams (Carbide 3D))
2
You need to enter the taper angle, not the nominal angle, so a 90 degree endmill tapers 45 degrees on each side (half 90), so enter 45.
Interesting… so does that mean my 60deg 1550 should be entered as 30deg (per side)?
Edit: yup, looks like that worked. Just cut with the 60deg bit and it looks great.
