Have a project I am doing for a family member.
Specifics:
Polycarbonate .250
Bandit image sitting in a triangle
The Interior and exterior of the image will be cut about .002 deep so the image will be slightly raised.
Had to do some editing of the lines after I scanned.
You can see here I have left a segment unjoined, I can join later. You can also see that some of the interior images are joined to the outside. Tried to unjoin with node editor, only ended up with a mess.
Duplicate you object first
Select âPolylineâ, draw a line where you want to split:
Select both the polyline and the line to trim, then hit âTrim Vectorâ:
Click on the exterior part to delete it, then delete the polyline:
Use polyline to join things up:
Maybe I am thinking outside the âtriangleâ here, but what if you allow the image to hang outside the triangle as a whole and not worry about trim, and cut through the overhanging image?
