Usually when do toolpath in CC I can select one or multiple object by pressing control button select the object with the mouse. But in CC-Pro the way to select more then one object is to do loop with the mouse. I use windows version. Any suggestions while I use the Pro version?
The key for multiple selection is now shift.
I find it best to group things in the Design pane, switch back to it and select the group, then with that selection active, switch to the Toolpath pane and assign a toolpath to the entire group.
