Mortise and tenon should be quite simple, and we’ve done dovetails:
That said, I find the vertical work holding fussy and annoying since it requires at a minimum three setups:
- one to cut features and cut to length
- one for a pair of corners cutting four boards at once
- one for a the other pair of corners cutting the other ends of the four boards
I’ve got a couple of additional joinery techniques to try out which will hopefully be a bit more efficient and expedient — just have to find the machine time.
