david5
(David Mattice)
May 5, 2023, 4:06pm
1
What are the steps to add a new bit to the library. I have a 1.5” surfacing endmill to add
WillAdams
(William Adams (Carbide 3D))
May 5, 2023, 4:13pm
2
First, create a new User Library, then add the tool.
Note that it is best to have the decimal separator set to period.
See:
This is a bit different — the tools are now stored in CSV files (do Help | About | Open Data Directory to access the carbidecreate/tools directory), and it is first necessary to add a New Library:
[image]
after clicking on the “New library” button you will get the “Create new library” dialog:
[image]
make appropriate selections (note that certain endmills only appear in certain materials — at this time, MDF has the most complete listing — further note that one aspect of this is the suitabil…
CullenS
(Cullen Simpson)
May 5, 2023, 7:37pm
3
Is it possible to edit the library to remove un-needed selections?
I don’t need the Nomad or HDM sections and those just push the ones I do want to the bottom.
Zman
(MICHAEL ZEMANEK)
May 5, 2023, 7:41pm
4
Yes See below. Choose your machine.
CullenS
(Cullen Simpson)
May 5, 2023, 8:23pm
5
DOH!
I am a Simpson after all, so I can use that line.
system
(system)
Closed
June 4, 2023, 4:06pm
6
