I have a Freud 3/4" mortising bit (model FRE16-104) which I would like to add to the tool database. This will be used for flattening my wasteboard.
Where do I find the values to enter in the database.
The following information (except for the geometry) was auto-filled.
How do I find valid values for cutting parameters ?
Thanks, Bill
Freud, FRE16-104
#1
Geometry
Diameter:
0.750 in
Flute Length:
0.500 in
Included Angle:
0.0
Num Flutes:
2
2D Cutting Parameters
Feed Rate:
10.0 in/min
Cut Depth:
0.050 in
RPM:
10000
3D Cutting Parameters
Feed Rate:
10.0 in/min
Stepover:
20.0 %
RPM:
10000
Finish Allowance:
0.100 in
