Adding tabs? How in version 726 of CC?
Please help me figure out my tabs. I’m learning how to use the new version of CC.
I cutting out a simple circle and can’t figure out how to add tabs to it.
As you can see, it thinks it’s one vector. How do I add vectors so I can add tabs to my circle cut out?
I brought the file in from Illustrator. See image attached.
I click on “change vectors” and “select current vectors”, but nothing happens.
Thanks!
As noted at:
Tabs are now a part of the vectors, not contour toolpaths.
We added a new tab command to add tabs to a vector. If you copy the vector, you copy the tabs too. This should be helpful for users that are doing production work where they may want to fine-tune the machining of a single item and then copy and paste an array of them for full production.
Look for the new command here:
New tabs command
Finally worked, thanks!
