state of wisconsin catch all.c2d (712 KB)
Hello all, I need help figuring out how to add text after i use the pocket tool path. Im guessing my starting depth is incorrect. Any suggestions would be appreciated. Thank you
You are correct. Use the Max depth from the pocket path as the start depth for the text path.
The start depth is the plane where the text vectors get traced. And the level where it starts removing material. Your max depth for the text will be the start depth plus the actual depth. i.e. the max depth is measured from the top of stock, not from the start depth.
Im not sure i follow lol but ill mess with it more. thanks.
I figured it out.Thanks
