I’ve got an old Sparkfun edition Shapeoko 3 that I rebuilt, then tore down to add a Z-Plus onto. The problem is, the Z-Plus technically requires the Proximity Sensors that aren’t compatible with the PCB I currently have.
I figured I could 3D print a solution to mount the physical limit switches onto the Z-Plus, so I thought I’d ask here first.
It wouldn’t be a problem to just spend the $50 on the proximity sensors, but I would also have to upgrade to a new board ($150) and buy a new router, as those sensors aren’t compatible with the DeWalt, so that kind of makes it a no-go.
So, has anyone either found a way to use physical limit switches on the Z-Plus or to make the Proximity Sensors work on an unsupported board?
Thanks for the replies!
And sorry for the double post. I was trying to look at the options on my original post and fat-fingered the delete button. Whoops.
Good to hear I’m not totally crazy in thinking that’s feasible. I just have to break out the calipers and get in some CAD practice and 3D print something.
What size shapeoko 3 do you have? I just upgraded my xxl to z plus and I bought new proximity switches due to the z plus in stock only came with the standard length cord proximity switches. Long story short I have proximity switches for a standard or XL model if your interested?
