I have been using the workflow stated in the title to make 2D cut paths and it works great. I love Illustrator and exporting as an SVG is a great way to get the info to Carbide Create.
However, after I updated to the latest Carbide Create (totally worth it thank you!) I have noticed that when I import an SVG from AI it is scaled down ca. 1/3. Has anyone else noticed this?
When I export an SVG from another program it loads fine. Such as Sketchup.
Curious if I can get some help figuring out if this is my bad on the export settings or potentially a bug.
Let me know what files I should upload, screenshots to grab, or settings to write down to make this as easy as possible.
The problem is that there isn’t an agreed-upon definition of how resolution / size will be specified for SVGs — best thing to do is to draw a rectangle of known size around the drawing and then check the size of that rectangle and its contents after import.
Please send a sample SVG in to us at support@carbide3d.com with notes on: size in Illustrator, SVG export settings used, size it imports at and we’ll try to have a developer look into this.
